Need some instructions on Negatron - How to list only existing ROMs ?
Re: Need some instructions on Negatron - How to list only existing ROMs ?
Hi Mr. Cyril,
I did finish the translations, Portuguese (me) and Spanish (a friend of mine). How Can I send you the files ?
Regards,
Regards,
You can send them to my email address: cyril.apan _at_ babelsoft.net, just replace " _at_ " by "@".
I see, Mr. Cyril, I uploaded to my Mediafire account and here's the link: http://www.mediafire.com/file/8zwkhdfqr ... n.zip/file
Ok ?
I hope it helps,
Best regards,
Ok ?
I hope it helps,
Best regards,
Thanks. I've just released Negatron 0.99.0.
On Linux and macOS, it must be used with NegaMAME, my own MAME derivative, otherwise some unexpected errors will be raised by Negatron when trying to launch some games. I've provided a complete NegaMAME pack for 0.198 but the only difference with regular MAME is the main binary file that I renamed as negamame64. You can just put this binary file into a MAME installation folder to make it work as everything else is the same.
Hey Agent Smith, 0.99.1 is ready for release!
Could you and your friends update your translations? There are about 16 new lines to translate.
Just take the 2 files:
https://github.com/xinyingho/Negatron/b ... properties
Search for the lines containing "###" i.e. 3 pound signs and, when finished, please send me your updated translations.
Dear Mr. Cyril,
I'm kinda busy this weekend, next week things will be better. If you can wait until Tuesday, I'll be able to help.
Ok ?
Best regards,
Ok ?
Best regards,
Thanks, that's perfect
Hello, when do you think you and your friend will finish to update the 2 translation files?
Hi There Mr. Cyril,
It turns out that my tasks took much longer than I anticipated, and my friend, who's a Spanish speaker, went on vacation.
I'm going to work in your file today, Monday, 16/07/2018, and will try to send it back to you by the end of the day.
I forwarded the Spanish files to my friend, but he's abroad and I don't know if he'll answer me the same day.
Ok ?
Ok ?
Hi Mr. Cyril,
It's done, my colleague answered me and I'm forwarding to you the files.
Ok ?
Here's the link: http://www.mediafire.com/file/1r91g2eel ... n.zip/file
Ok ?
Best regards,
Ok ?
Ok ?
Best regards,
