Add Support For TBN Image Format
I don't know if I'll add official support for TBN as this is just some jpg thumbnails generated by XBMC. In the meantime, you can simply add this extension as an image user defined extension (go to the "Image Formats" tab of the configuration tool), you don't have to manually edit your registry.
