...even though I selected do not install it.
Is that normal?
I really dont want to use MP for images and audio as I have no need.
thanks
New beta installs Image and Audio shell
ASUS Sabertooth 990FX AMD FX-8350 Zalman 9900NT G.Skill F3-2400C10-8GTX 16GB XFX Double D R9-280X-TDFD 3GB 384Bit GDDR5 HT Omega Claro Plus Windows 7 Ultimate 64bit SP1 APC Back UPS XS1000
Re: New beta installs Image and Audio shell
Indeed, it's not normal.
Did you install the latest beta (b4)? Did Media Preview register itself to every image and audio formats although you didn't check any formats in the MPConf tool? Or just 1 or 2 formats?
It's difficult to diagnose this kind of issue without direct access to your system registry. So if you could export and send me your HKEY_CLASSES_ROOT branch, I could look at it closer and take a guess at what happened. Send it to me by email or by PM in order to not disclose any of your personal information on the web
Edit: oops, I read your message too fast, it's about installation, not about configuration.
I never tested the case of when you uncheck image and audio extension shell. I'll go fix this then!
