Hi, it should work on Windows 10. I've recently migrated to Windows 10 this Summer and Media Preview is working well here.
On what kind of files doesn't it generate thumbnails? If you can isolate one video file having this issue and send it to me, it would be even better.
Really weird, you shouldn't need to use the target area. It means that, maybe, Media Preview is blocked on an invalid video file or a file using a very recent codec as VP9 and thus spends a lot of time trying to generate a thumbnail on this particular file before moving on to the others. By "isolating", I meant find a file with the issue and send it to me. But if it seems like every file has the issue, then try to move a few video files to another folder and see if Media Preview still don't generate anything. If it then works in the original folder or in the new folder, it means that the blocking file is in the folder where you still can't see thumbnails.
I probably need to update Media Preview with up-to-date codecs to better handle recent codecs that are more and more widespread...
BabelSoft wrote:Do you have any issue with Windows 10 as well? Can you describe further what's wrong?
I guess I didn't feel comfortable using something like this when someone had an issue. I was just wondering if people were still having problems. I've had bad experiences with implementing UI and thumbnail changes in windows that were irreversible. (I will never install VisualStyle DLL replacers ever again)
Windows 10 isn't the issue.
But you may get some issues if you have some videos encoded with VP9 or HEVC --> Media Preview may loop for a very long time on those videos. But in practice, there are very few videos encoded with those recent codecs in the wild.
BabelSoft wrote:Windows 10 isn't the issue.
Thank you for the info then. I'll give this a try.
